Bongo Free Top weather seal.
rev pete
Post by rev pete » Fri Mar 05, 2010 12:31 pm
Can anybody tell me where I can get a free top seal I notice that mine has perished and starting to split. Also are they difficult to fit? it looks as though they push into place like a normal car door surround. Thanks folks, The people here are very helpful so thanks again. Pete :)
Re: Bongo Free Top weather seal.
Post by g8dhe » Fri Mar 05, 2010 1:28 pm
Which seal are you referring to ?
  • There is the seal between the lower tent frame and the roof of the vehicle itself - that's a strip of "sticky back foam" which I've replaced see here http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=34592
  • I guess there is a seal of some type on the top tent frame to the GRP, although I have replaced some of the screw fixings I didn't notice a seal as such.
  • and finally I guess the seal between the AFT top and the vehicle roof, but that seems to be some sticky back material that folds over the edge of the roof itself.
Post by mikeonb4c » Fri Mar 05, 2010 2:29 pm
rev pete wrote:Can anybody tell me where I can get a free top seal I notice that mine has perished and starting to split. Also are they difficult to fit? it looks as though they push into place like a normal car door surround. Thanks folks, The people here are very helpful so thanks again. Pete :)
Good enquiry Pete as I think it will come up more and more. Mine is a tad tired in one small spot and I'm trying to think whether it could be stabilised by rubbing e.g. Evostick or tyre repair solvent into it to 're-rubberise' it a bit and close the cracks from more freeze-thaw/moisture ingress.
But otherwise, its time we started a debate on here about how to replace old ones :roll:
helen&tony
Post by helen&tony » Fri Mar 05, 2010 3:12 pm
I've used these folk since the 60's:-
http://www.rubbertrim.co.uk/
I had posted a link on here before, but darned if I can find it :lol: :lol:
Clip off a bit of what you want, and send it to them....and temporarily seal the bit you cut off with some tape.....order a tad more than you measure, plus a bit for spare.
Post by mikeonb4c » Fri Mar 05, 2010 3:19 pm
helen&tony wrote:Hi
Good tip Hellen. =D>
I occurs to me it might be possible to make a mould using e.g. polyfilla then a sample using e.g. bath sealant rather than having to damage the existing seal? Need to tell them if you think the existing seal is a hollow (I think it is) x-section.
helen&tony
Post by helen&tony » Fri Mar 05, 2010 3:30 pm
If it's hollow, Mike, you need to get a piece of connector tubing to go in the hollow section...not forgetting to use rubber cement when assembling....also, cut a little longer than you want, and force the edges together. When fitted, keep the rubber talc-ed.
rev pete
Post by rev pete » Sat Mar 06, 2010 2:17 pm
The seal I refer to is the rubber one that squashes under the lift up roof to seal to the vehicle roof when it closes. I have not studied it and was hoping somebody might have done it all before.
helen&tony
Post by helen&tony » Sat Mar 06, 2010 4:16 pm
That firm I posted the link to carry all that sort of stuff. It's an easy job , and anyone can do it , but make sure you buy too much, as you can't stretch it if you don't buy enough :wink: :lol:
rev pete
Post by rev pete » Sat Mar 06, 2010 4:24 pm
Thats Great Thanks a lot for your advice =D>
Post by mikeonb4c » Sat Mar 06, 2010 5:51 pm
rev pete wrote:Thats Great Thanks a lot for your advice =D>
Keep us posted Pete and good luck 8)
rev pete
Post by rev pete » Sun Mar 07, 2010 12:37 pm
Hi I contacted Messrs Rubbertrim and told the I needed a weather seal for the edge of a lift up roof on a 1998 Mazda Bongo I had a reply that just said "Sorry I cannot supply" My next port of call will be Wheel Quick. I will keep you up dated..... :?
Rhod
Post by Rhod » Wed Mar 10, 2010 10:44 pm
Try JustKampers - they stock trim for the various VW pop-tops. I had a look at their catalogue a year or so back & it looked as if either the general purpose seal for Dormobiles/Vikings/Devons or the general purpose Westfalia seal (right-angled) would fit. Can't remember which one it was now, but I've a feeling that the Bongo seal might be right-angled. Too dark & late now to go out & raise the roof to check I'm afraid :)
Post by mikeonb4c » Thu Mar 11, 2010 12:26 am
Rhod wrote:Try JustKampers - they stock trim for the various VW pop-tops. I had a look at their catalogue a year or so back & it looked as if either the general purpose seal for Dormobiles/Vikings/Devons or the general purpose Westfalia seal (right-angled) would fit. Can't remember which one it was now, but I've a feeling that the Bongo seal might be right-angled. Too dark & late now to go out & raise the roof to check I'm afraid :)
Good thought there Rhod =D>
Maybe we should drop then a hint that Bongo ones might sell well before too long should they decide to put one in their catalogue :roll:
Can you recall what prices were like (roughly?) (I'm off to google them and see if I can find out online) 8)
Post by mikeonb4c » Thu Mar 11, 2010 12:32 am
Westfalia one looks like it might be 45GBP on their very interesting looking site at:
http://www.justkampers.com/search2?loca ... filter[]=0
Fingers crossed we might get something sorted for Bongos at an affordable price (though I reckon it must be rather more than that figure :roll: )
I wonder how easy it would be to remove the old and fit the new :roll:
rev pete
Post by rev pete » Thu Mar 11, 2010 12:42 am
A Brilliant site for lots of stuff I will check my roof and get a new seal for it. BONGO FURY MEMBERS ARE GREAT Long live the Brilliant BONGO :D
