hi guys , im going to be changing the water pump in next few days ,
can anyone advise me on the belt tension?,, i can see the alternator belt is adjusted on the top bracket....
any advice most welcome
cheers
ricky
have yourself a midlife chrisis,,,,go buy a bongo!
There's a fact sheet in the members area on doing the water pump, being able to twist the belt by 90 degrees is a reasonable approximation, just don't be tempted to over tighten or you'll knacker the bearings.
