Triple/R
Post
by Triple/R » Mon Feb 22, 2010 3:25 pm
Regards Ray & Christine
Post
by francophile1947 » Mon Feb 22, 2010 3:59 pm
Disconnnecting the battery has lost the radio's memory - probably just needs retuning to pick up the Japanese channels again. You can get a band expander which will allow it to work in the UK, although the programs won't be where you're expecting them
TV is useless over here
No idea about satnav, unless you can get the relevant software for the UK. As you correctly said, best to bin it and get a proper one
Triple/R
Post
by Triple/R » Mon Feb 22, 2010 4:10 pm
francophile1947 wrote:Disconnnecting the battery has lost the radio's memory - probably just needs retuning to pick up the Japanese channels again. You can get a band expander which will allow it to work in the UK, although the programs won't be where you're expecting them
Cheers John--when i took the battery out of my last Bongo then put it back the radio came straight back on---so i expected this one to
I'm going (eventually) buy a new Radio but would rather see this one work albeit crap
just to be sure wiring etc; is ok.
Post
by francophile1947 » Mon Feb 22, 2010 4:23 pm
ADAMD
Post
by ADAMD » Mon Feb 22, 2010 4:53 pm
Mine had AV inputs, Ideal for plugging in an Ipod.
You can also playback from a digital camera, if you set the output to NTSC.
The only use for the sat nav was for marking speed cameras, press down on the joystick as you pass one
and next time it makes a noise as you approach, well It did on mine.
Rhinoman
Post
by Rhinoman » Mon Feb 22, 2010 5:08 pm
Sat Nav should work OK with the correct maps, the CD shows it to be a Clarion system so you ought to be able to find updated software somewhere on the web. The screens says its a TV monitor so I would expect the Satnav box to have AV outputs, its possible to but the GPS boxes on their own. Whatever you do don't bin it.
1995 Ford Freda, 2.5TD, auto, AFT, side conversion.
Triple/R
Post
by Triple/R » Mon Feb 22, 2010 6:58 pm
Thanks for comments so far
no i did'nt really want to bin it.
dandywarhol
Post
by dandywarhol » Mon Feb 22, 2010 7:13 pm
wire in a reversing camera to impress the neighbours
Triple/R
Post
by Triple/R » Mon Feb 22, 2010 7:23 pm
dobby
Post
by dobby » Mon Feb 22, 2010 8:55 pm
catzi
Post
by catzi » Mon Feb 22, 2010 10:10 pm
I'd get hold of a Japanese Super Nintendo (Super Famicom) for a spot of in-Bongo retro gaming!!!
I Bongo therefore I am
Triple/R
Post
by Triple/R » Tue Feb 23, 2010 12:19 am
Eyup Graham--do you mean buy one like carls
i do'nt really want one of them--i wan't to use wot ive got (if possible) if it can't be used i'll take it out put a modern Radio/CD & cubby with clock
Anyway anybody got the answer to why the radio do'nt work please.
dobby
Post
by dobby » Tue Feb 23, 2010 12:29 am
Ok, I'd find a fluent japanese speaking auto electrician or press all the buttons until works
Seriously as per previous posts, does it have a separate AV input? Maybe use it with a freeview box, ipod or reverse cam etc?
Best of luck
jaylee
Post
by jaylee » Tue Feb 23, 2010 1:12 am
Could it be the radios disabled when the top bit of big screen gubbins is switched on..?
ADAMD
Post
by ADAMD » Tue Feb 23, 2010 9:54 am
Jaylee,
Is the Radio now completely dead, or does it light up? Can you get hiss through the speakers if you try the TV?
Radio should work when screen is in use, but screen takes over if on TV or AV.
