Central Locking
M&K
Central Locking
Post by M&K » Fri Feb 19, 2010 9:32 pm
Hello, our central locking has packed up, would anyone know where it is located ?
Cheers,
Mike.
mikexgough
Re: Central Locking
Post by mikexgough » Fri Feb 19, 2010 9:35 pm
probably a broken wire in the drivers door jam.....the loom from the vehicle to the drivers door.... purple wire with a stripe If I remember right if not check the fuse.....fuse 4....... top row....4th from the left
You've Been Bongod
Re: Central Locking
Post by You've Been Bongod » Fri Feb 19, 2010 9:55 pm
take the glovebox off and there is a grey relay behind it
that was what was up with my old bongo
if it is that expect to pay around £15 plus post from ebay
Re: Central Locking
Post by missfixit70 » Fri Feb 19, 2010 10:00 pm
M&K wrote:Hello, our central locking has packed up, would anyone know where it is located ?
Cheers,
Mike.
check there's enough voltage for it to work, mine runs off my LB & it was the first sign I had LB problems, or check the fuses, fuse list in the members area.
jaylee
Re: Central Locking
Post by jaylee » Fri Feb 19, 2010 10:16 pm
I love this picture... C/L relay... Yours may be a different colour..? (They do sometimes differ in shades & hue.) :D
Sluggy
Re: Central Locking
Post by Sluggy » Tue Jul 13, 2010 11:52 am
Hello,
Mine has done the same this morning, the remote fob opens the drivers door and deactivates the alarm but the other doors don't unlock...
I've checked fuse 4 and the door wiring loom, both seem fine. could this be a faulty relay then?
:D
Re: Central Locking
Post by g8dhe » Tue Jul 13, 2010 3:26 pm
There are two fuses involved;
Above controls the motors
controls the switching.
Sluggy
Re: Central Locking
Post by Sluggy » Tue Jul 13, 2010 3:30 pm
It was the wire from my LB split charger, it had come loose from the no.1 fuse position it is installed at.
Thanks for the help g8dhe! :D
