Heat sensor light/lampda sensor.
Could someone help me with the above problem. In the recent heavy rain I went through what I thought was shallow water, but which turned out to be quite deep and the heat sensor light came on. I was advised by the breakdown service that the lampda sensor has probably been affected by the water and to leave it a short while to see if it would dry out. The light is still on so I assume the sensor is now no good. I spoke tothe nearest garage that deals with Bongos and was told that it would cost £70 +vat for diagnostics report + £120.00 for the sensor + fitting. It seems rather expensive as the van is running well,but I dont know if Im doing any damage by using it. Is it an easy job to do, and where can I source a sensor. Im not particularly mechanical minded but am willing to try if there is simple instructions out there. PLEASE HELP! Thanks Kazanne
- missfixit70
Re: Heat sensor light/lampda sensor.
Just did a search on "lambda and sensor - http://www.igmaynard.co.uk/bongo/forum/ ... mit=Search - try the one on "universal lambda sensor" a few threads down.
- dandywarhol
Hopefully you haven't cracked the catalytic convertor by suddenly cooling it through the water - that could cause the lamp to come on
I assume it is a v6 thenKazanne wrote:Could someone help me with the above problem. In the recent heavy rain I went through what I thought was shallow water, but which turned out to be quite deep and the heat sensor light came on. I was advised by the breakdown service that the lampda sensor has probably been affected by the water and to leave it a short while to see if it would dry out. The light is still on so I assume the sensor is now no good. I spoke tothe nearest garage that deals with Bongos and was told that it would cost £70 +vat for diagnostics report + £120.00 for the sensor + fitting. It seems rather expensive as the van is running well,but I dont know if Im doing any damage by using it. Is it an easy job to do, and where can I source a sensor. Im not particularly mechanical minded but am willing to try if there is simple instructions out there. PLEASE HELP! Thanks Kazanne
If it the heat sensor it does nothing apart from tell you your cat pipe has overheated, prob due to raw fuel entering the exhaust system due to a missfire, goin on my experiances you prob took a missfire from the water and that has killed the heat sensor, is it still missfiring
Remember the heat sensor and lambda are not connected in anyway the heat sensor does not control your fuelling as far as i know
TRUST ME THE V6 DON'T LIKE LOTS OF STANDING WATER, i sorted my o ring a long time ago but still get grief from the rear plug on driverside with water ingress. the prob is that if you hit lots of standing water it comes up through the scav fan on a direct collision course with the dizzy cap, it also sits on the rocker cover aswell untill you go up hill then it ends up in the rear plug
Dar
Thanks cheffy its not the first time have had a problem but last time it went off after a day. The van didn missfire at all and hasnt done since. Seems fine running really well, its just that sometimes we pull a small caravan and I was worried it might affect this. Dontknow anyone with a scanner and my usual mechanic seems to have disapeared. Dont know anyone around the Southend on Sea/Westcliff area with a bongo or anyone who fixes them. Dont think I am up to what you suggest to try, not sure what to do now? Anyone know a bongo fixer this part of essex. Yes it is a N Reg V6 Petrol. Regards Kazanne
- missfixit70
Have you checked the bongo friendly garage list in the members area?
No I havent actuall ywill do that thanks.
Kazanne wrote:Thanks cheffy its not the first time have had a problem but last time it went off after a day. The van didn missfire at all and hasnt done since. Seems fine running really well, its just that sometimes we pull a small caravan and I was worried it might affect this. Dontknow anyone with a scanner and my usual mechanic seems to have disapeared. Dont know anyone around the Southend on Sea/Westcliff area with a bongo or anyone who fixes them. Dont think I am up to what you suggest to try, not sure what to do now? Anyone know a bongo fixer this part of essex. Yes it is a N Reg V6 Petrol. Regards Kazanne
Strange it went off after a day
Me? Im the cowardly lion. Is what breaking off and where in the cat pipe is it? Perhaps Ill just disconnect it and forget about it! Regards Kazanne
