FRONT HEATER FAN
peage123
FRONT HEATER FAN
Post by peage123 » Fri Feb 05, 2010 9:10 pm
CAN ANYONE TELL ME WHERE THE FRONT HEATER FAN IS LOCATED AND HOW IT CAN BE IDENTIFIED AND GOT AT MINES NOT WORKING CHECKED FUSES ETC STEVE CHESHIRE
You've Been Bongod
Re: FRONT HEATER FAN
Post by You've Been Bongod » Fri Feb 05, 2010 9:15 pm
Hi Steve the heater is located under the bonnet its towards the passenger side
daveblueozzie
Post by daveblueozzie » Fri Feb 05, 2010 9:29 pm
Lift the air scoop off and the fan is under the scoop, gently push it see if it moves.
Lost without my Bongo.
Post by missfixit70 » Fri Feb 05, 2010 10:15 pm
mikes
Post by mikes » Tue Feb 16, 2010 12:28 am
Replaced mine, £50 from "Need a Part" second hand.
Remove plastic intake, then the square intake box under that and you'll see the fan underthat. If the fan still works on full power only, then its probabaly the resistor that needs replacing. That is a little aluminium finned cube. Its central under the bonnet behind the fuse box under a black plastic cover. its fitted upside down and not immediately visible, 2 screws to undo and take out.
Hope thats a help.
Post by missfixit70 » Tue Feb 16, 2010 12:33 am
Or if you click on my link to the FAQ, you can fix the fan & resistor pack for nowt :wink:
