My radio is powered from the leisure battery so that the radio can be played whilst the engine is off etc. However, the BEAT600 doesn't have the facility to switch off fully. It leaves lots of pretty LED's around the facia switched on, even when the unit is powered off.
the iso wiring loom has:
- Black: ground
- Red: 12v (fused): which i think is meant to be wired to the ignition in a normal car but on my bongo is wired through the LB instead. i.e. always on.
- Yellow: 12V permanent (fused): which I think is wired direct to the battery (for clocks, 'memory' etc)
(I will add photos of the install when the double din chassis arrives. I am also wiring in solar panels and an inverter - handy for multi-day mountain bike races where there is no hookup.)
