glow plug relay again!!
kiddiekool
Post by kiddiekool » Mon Jan 25, 2010 11:42 pm
I have been having problems with my glow plug relay unit ( I think??) basically my glow plugs were first replaced due to white smoke when starting, but once they were changed it then would start but not catch, so my mechanic assumed my glow plug relay unit had blown due to my glow plugs previously not working :? so new relay was put in and has lasted around two weeks :( .It seems to have blown again. Is there some underlying problem which could cause this as I dont want to have to keep replacing relay.
dandywarhol
Re: glow plug relay again!!
Post by dandywarhol » Mon Jan 25, 2010 11:52 pm
See if the wrong length of plugs were fitted - the bus bar will short out on the pipes! You can add washers to shim it out of the way or bend the pipes.
waycar8
Post by waycar8 » Tue Jan 26, 2010 10:37 am
are you sure its the glow plug relay and not the fusable link?, its inline fuse behind the starter battery that goes the glow plug relay?
Post by missfixit70 » Tue Jan 26, 2010 4:40 pm
check to see if you're getting voltage at the glowplug busbar when the key is turned, that'll give an idea of what's doing what or not.
