Fuel guage problems/oil leak
muddypaws
Post by muddypaws » Wed Jan 13, 2010 12:05 am
Since the cold weather started, I've had problems with my fuel guage. It will read half a tank one minute and then empty the next and so on....all over the place. Very confusing and I'm constantly paranoid and have now lost track of how much I might have in there. Right pain in the rear!
Is this a common problem? Is there an easy way of replacing the sender unit? I have a feeling it is that rather than the guage but any advice would be greatly appreciated!
jaylee
Re: Fuel guage problems?
Post by jaylee » Wed Jan 13, 2010 12:10 am
jaylee
Post by jaylee » Wed Jan 13, 2010 12:12 am
Or this... http://www.igmaynard.co.uk/bongo/forum/ ... fuel+gauge :wink:
Once you get to the top of the tank, try disconnecting the connector on the top of the sender, then start the ignition & wait a couple of minutes & see what the gauge does..? I should move to the full position... (regardless of how much fuel is in the tank.) If NOT then it could actually be the fuel gauge itself!??
muddypaws
Post by muddypaws » Wed Jan 13, 2010 12:38 am
Brilliant!!! As usual! Ta very much! I will pass all that info on to my husband at the weekend and supply coffee whilst he fixes! :wink:
muddypaws
Post by muddypaws » Wed Jan 13, 2010 12:39 am
Don't suppose you could tell me where my oil leak is too? lol
jaylee
Post by jaylee » Wed Jan 13, 2010 12:47 am
muddypaws wrote:Don't suppose you could tell me where my oil leak is too? lol
:lol: Now that could be coming from any where... Like a dodgy oil filter seal..?
Can you be more specific..? :wink: Where about's under the van is it dropping?
muddypaws
Post by muddypaws » Wed Jan 13, 2010 9:00 am
I know...can't believe it has an oil leak! :(
DH says he thinks it is the front of the engine. He's very annoyed as it could obviously be any number of seals.
Post by missfixit70 » Wed Jan 13, 2010 2:37 pm
If the leak is on the drivers side of the engine just below the air inlet manifold, most have it, nowt to worry about, blanking the egr may help http://www.igmaynard.co.uk/bongo/forum/ ... 43&t=14463. Or it could be a slight weep from the rocker cover gasket, which may just need tightening down.
If it's coming from below the fuel pump & smells a bit dieselly, could be the fuel pump seals, there's a fact sheet on repalcing these I think & Ian stocks the seals in the club shop.
How's that for starters? :wink:
muddypaws
Post by muddypaws » Sat Jan 23, 2010 10:02 am
Thanks missfixit, will pass info onto dh! :wink:
Post by Ian » Sat Jan 23, 2010 1:13 pm
Just uploaded a factsheet http://www.igmaynard.co.uk/bongo/member ... sender.pdfto the members area on this subject. Thanks to Kirsty & Ben for the info (plagiarised from here) and to Matt at the Utility Research Bongo Kitchen for background data and technical authoring.
muddypaws
Post by muddypaws » Sat Jan 23, 2010 2:11 pm
Well, my son and I just got back from the cinema and dh had just finished the fuel guage job. I just put my mats back in whilst he had lunch and noticed that the guage is now reading half a tank without the key in the ignition! :shock: That ain't right is it?
He's just asked me to ask if anyone can tell us where the fuel guage fuse is please? He wants to check it.
mister munkey
Post by mister munkey » Sat Jan 23, 2010 2:21 pm
It should stay where it is with the ignition off, thats normal.
Unless of course its showing half a tank when you've just filled it, thats not.
muddypaws
Post by muddypaws » Sat Jan 23, 2010 2:31 pm
mister munkey wrote:It should stay where it is with the ignition off, thats normal.
Ah ok, I always thought it went back to empty when you turned the ignition off. We're gonna go fill her up in a mo and see how many litres it takes to fill. If its half 65 then it should be workin fine hopefully and we'll take it from there. DH did what everyone here advised though by re earthing and testing with meter etc...thanks everyone and fingers crossed. Watch this space! :wink:
Post by missfixit70 » Sat Jan 23, 2010 2:52 pm
If it's anything like mine, it'll show overfull when you fill it, & will take a while to start coming down as you use it, certainly not linear, as it says in the factsheet :wink:
mister munkey
Post by mister munkey » Sat Jan 23, 2010 2:59 pm
Saying that, mine is at the opposite end of the scale. It only shows about seven eighths when brimmed but will drop below the E & still have 15/20 litres left.
I can play Fuel Guage Roullette for a good 50 miles & still only manage to squeeze 50 litres in.
