ECU information required
widdowson2008
Re: ECU information required
Post by widdowson2008 » Mon Jan 18, 2010 1:04 am
The Great Pretender wrote:I may have missed it Steve, does the ECU still receive power when the ignition is off?
Not got to that part yet but I think it must. According to the manual, pin 2B on the ECU is shown as being connected to the batery and the signal name is 'Back up power'. This implies (to me anyway) that the ECU is permantly powered. Thinking about it, it must be powered or the fans wouldn't kick in when you remove the ignition key ................(would they?).
Yet ANOTHER thing to check :wink:
Steve
The Great Pretender
Post by The Great Pretender » Mon Jan 18, 2010 1:30 am
Not got to that part yet but I think it must. According to the manual, pin 3B on the ECU is shown as being connected to the batery and the signal name is 'Back up power'. This implies (to me anyway) that the ECU is permantly powered. Thinking about it, it must be powered or the fans wouldn't kick in when you remove the ignition key ................(would they?).
The more you dig, the deeper the hole.................. :wink:
To infinity and beyond
widdowson2008
Post by widdowson2008 » Mon Jan 18, 2010 1:34 am
Tell me about it :shock: ......................but its a nice symetrical, well formed, comfortable hole.............If I don't surface before June, bring a shovel :wink:
Steve
Post by g8dhe » Mon Jan 18, 2010 1:38 am
Yes it does Pin 2B;
widdowson2008
Post by widdowson2008 » Mon Jan 18, 2010 1:47 am
Stand corrected (by Geoff) It is 2B and NOT 3B as I said :roll: Weeeeeeeeell, you can't get it right ALL the time :oops: :oops:
Steve
The Great Pretender
Post by The Great Pretender » Mon Jan 18, 2010 1:59 am
Yes it does Pin 2B;
I will take your word for it, electrickery is my Achilles heel. Is the power just for the memory? Can the ECU supply power to the fans when ignition is off? I suspect if it does it does it via a negative feed to a relay. Is this correct, or am I barking up the wrong ECU............. :lol: :lol: :lol:
widdowson2008
Post by widdowson2008 » Mon Jan 18, 2010 2:06 am
To complete the ECU schematic, I am looking for the circuits connected to ECU pins:
2D, 2E, 2O, 2P
3A, 3B, 3C, 3D, 3J, 3L, 3R
Can you point me in the right direction? or even better, can you email the relevant pages so I can print them off please?
Steve
widdowson2008
Post by widdowson2008 » Mon Jan 18, 2010 2:57 am
Yes it does Pin 2B;
No idea on this one. From the diagrams, for the fan motor to work, the coil needs to be energised, and I can't see where it would get the power from. :roll: :roll: We need a sparky pronto.
Steve
Rhinoman
Post by Rhinoman » Mon Jan 18, 2010 10:20 am
According to the schematics only the scavenger fan can run when the engine is off.
1995 Ford Freda, 2.5TD, auto, AFT, side conversion.
widdowson2008
Post by widdowson2008 » Mon Jan 18, 2010 10:32 am
Rhinoman wrote:According to the schematics only the scavenger fan can run when the engine is off.
And the solenoid part of the relay connects to the ECU, pin 3X.
Hi James
How is the exploration into the bowels of your ebay ECU progressing?
Steve
Rhinoman
Post by Rhinoman » Mon Jan 18, 2010 12:21 pm
widdowson2008 wrote:Hi James
I'm not due to receive it for a couple a days.
Post by g8dhe » Mon Jan 18, 2010 1:08 pm
widdowson2008 wrote:Geoff
2D, 2E, 2O, 2P
OK see PM
Post by g8dhe » Mon Jan 18, 2010 1:21 pm
The Great Pretender wrote: Is the power just for the memory? Can the ECU supply power to the fans when ignition is off? I suspect if it does it does it via a negative feed to a relay. Is this correct, or am I barking up the wrong ECU.............[/color] :lol: :lol: :lol:
Can't say specifically as I don't have a circuit diagram for the ECU, but more than just the memory as things like the Scavenger Fan relay are operated from it when the Ignition is off!
But there are two other power connections Pins 1C & 1D that are switched via the Ignition key - part of this might be safety as you don't want other fans etc kicking in if it goes wrong!
Which side is switched depends on the load, Relays and Solenoids are seem to be high-side switched (supplied with +12v) whilst dashboard lights etc are given an earth to light them.
widdowson2008
Post by widdowson2008 » Mon Jan 18, 2010 2:18 pm
Another query?
Thanks for the pm Geoff. =D>
What does FICD stand for? #-o
Last edited by widdowson2008 on Mon Jan 18, 2010 2:32 pm, edited 2 times in total.
Steve
rita
Post by rita » Mon Jan 18, 2010 2:25 pm
widdowson2008 wrote:Another query?
Fast Idle Control Device
