confused about over heating devices
as a relative newcomer to this site, i think i have read just about every thread related to overheating , and i am now more confused than when i started.
i fully realise the importance of having early warning of overheating ,( and the costs of not having it ) but what i now cannot figure out is ,what devices do i need as protection. there seems to be alot of options
the TM2 appeals to me for its digi readout etc ,but i do,nt think this covers early warning of coolant loss.
so to clarify things can someone please, give me a list/name of what i need , and equally important where to get each device.
as to installing these things, well that comes later !!!
the cost of these items is relatively unimportant , compared to the possible costs of not having them
thanks in advance
bobngo
thanks in advance
bobngo
- hembramacho
Re: confused about over heating devices
If you hold your horses there might be a fact sheet on this very soon.
In the meantime have a look at this thread - may be useful?
http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=37233
Andrew
Andrew
- widdowson2008
Hi bob
First thing to do is read through this VERY current post dealing with your problem (I think)
...........AND ........a fact sheet is being produced at this very moment
bugger.........Andrew beat me to it
Steve
thanks for the prompt answers, yes i,ve read that link (and others)
how will i know when that fact sheet is out, and where will i find it ????
and if it overheats between now and then , life as i know it will end , could not live without my bongo
did,nt mind the wife going but the bongo is altogether much more serious !!!!!!!
- haydn callow
I have sent a PM to you.....the fact sheet is done and is being approved edited at this moment. It will then go up to HQ for inclusion in the fact sheet archive, subject to Ian's approval
- mister munkey
Short term, the 1st & cheapest option is to stck a Mason in.bobngo wrote: and if it overheats between now and then , life as i know it will end , could not live without my bongo
A twelve year old can fit it in fifteen minutes & will give you a frontline warning of any temp increase.
- haydn callow
Even cheaper is the gauge "free" upgrade....(well !! 3p)
- stilldesperate
- Tribal Elder
Oops!
Last edited by stilldesperate on Sun Jan 10, 2010 9:34 pm, edited 1 time in total.
- mikexgough
Hold steady........ even when the fact sheet is produced..... it will be a case of choice and you pays your money......
Have you seen any of the gizmo's on a Bongo and spoken to owners yet?..... If not I would do and keep your cash in your wallet for now...... then choose what you want to have....All of the gizmo's have their merits..
For me, I ran 3 months without a Low Coolant Alarm and a further year without anything else...... and I spotted/smelt my coolant leak well before the alarm did, in fact it never did as I never allowed it too......I fitted another device after that coolant loss due my radiator seam leaking, for my own curiosity and for no other reason
mister munkey wrote:Short term, the 1st & cheapest option is to stck a Mason in.bobngo wrote: and if it overheats between now and then , life as i know it will end , could not live without my bongo
I got alot of respect for Haydn & Dave M... I got a Mason fitted thas all, & the Mase did warn me to stop when my top hose went in Oct 08.. But that ain't to say it's NOT a good idea to have something to warn you yer loosing coolant in the first place!!
- widdowson2008
I'm biased toward the TM-2 for 2 reasons:
1 - That is what I fitted to my Bongo and I am thoroughly chuffed with it
2 - it gives a readout in actual degrees C, not 'o-clocks'
There is another reason to do with dumbing a dumb gauge and getting a double dumb answer (measured in o'clocks)
Whichever unit you choose, NONE of them will prevent problems happening, but you will get an early warning so that you can deal with it before it starts to get into the cost zone.
Steve
- mikexgough
widdowson2008 wrote:Whichever unit you choose, NONE of them will prevent problems happening, but you will get an early warning so that you can deal with it before it starts to get into the cost zone.
Exactly...... nothing beats checking your levels in the 1st instance....BEFORE you drive off into the distance....then the gizmo you choose to haveon your Bongo can warn you of anything untoward.....while you are out and about
To check my level I use a chop stick that I have made a groove in to mark the correct level of coolant in the Header Tank....plastic, wipe clean and fits in the Leisure battery tray.... sorted...
- haydn callow
The Low Coolant Alarm checks the coolant level for you EVERY time you switch on the ignition.....How many peeps check the level every day let alone every time they switch on.....
- mikexgough
Raises Hand..........haydn callow wrote:.....How many peeps check the level every day let alone every time the switch on.....
- haydn callow
proposed factsheet sent to HQ for editing etc.....It may seem to some to be a bit of advertising. I was aware of this and tried to be constructive and give my honest opinion. But seeing that as far as I know I produce/import and sell 95% of them it was difficult to make it seem anything other than a series of advertising material.....It's done now and may be of use to some. Anyone want to add anything ...please contact Ian......
