cheers jim
i had the heating on full in the front but not the back.daveblueozzie wrote:did you have the heating on full blast back and front. that helps when your bleeding and trying to get the stat to open.
but it does sound like the thermostat, the bottom hose does not get as hot as the top hose.
i will have a look at the belt in the morn when thers more light .mister munkey wrote:Is the belt to the waterpump okay?
Sorry to disagree Dave, but by putting the heaters on, all you are doing is dissipating the heat quicker via the matrixes acting like radiators, therefore it'll take longer to get up to opertating temp & the stat open & the bottom hose warm. The only reason the heaters should be turned on is to check they are heating up ok & there aren't any airlocks.daveblueozzie wrote:did you have the heating on full blast back and front. that helps when your bleeding and trying to get the stat to open.
