whistling from fan/alt'/drive belt?
Re: whistling from fan/alt'/drive belt?
Post by mikeonb4c » Thu Nov 26, 2009 11:30 pm
carlioll wrote:I also have a squeeking noise when the engine is on tickover and is cold. Not a squeal like a belt slipping. At the last service, Wheelquick said it isnt worth bothering about and is connected to the cold start system and is very common. The noise disappears when the engine is revved and when the engine warms up all is quiet on tickover.
Thats you me and Alison then and no probs. Sounds like its just a Bongo foible :D
mister munkey
Post by mister munkey » Fri Nov 27, 2009 12:00 am
ashleywengraf wrote:Thanks for all this. I recently had the problem with the manifold bolt and had it replaced. There was soot
While you're next under the seat, check for soot again.
I had a stud go, had it replaced but soon after it went again because the manifold had warped & pulled the stud again.
Post by Doone » Fri Nov 27, 2009 10:11 am
There are several reasons why a Bongo will squeak and the most common reasons have been mentioned here, hope you sort yours soon. :)
