the guvnor
Post
by the guvnor » Wed Oct 14, 2009 11:37 am
As it says really ! I have a switch and havnt a clue what its for !
It is situated to the right of the stearing wheel....low down on dash....just above fuse box ! When i put it on it has a little light come on but not sure if it does anything !
Any ideas guys ?
Scott
Post
by Scott » Wed Oct 14, 2009 11:38 am
rear fog light ?
The user formerly known as csmcqueen
スコット
Post
by missfixit70 » Wed Oct 14, 2009 11:45 am
I'd agree with that, lights should have to be on for it to work.
the guvnor
Post
by the guvnor » Wed Oct 14, 2009 11:47 am
Hmmmm Will check that...........cheers guys
the guvnor
Post
by the guvnor » Wed Oct 14, 2009 11:54 am
It is rear fog light
Thanks for that, my mind is at rest
Scott
Post
by Scott » Wed Oct 14, 2009 1:23 pm
the guvnor wrote:It is rear fog light
Hmmm, I think every car I own now, I am going to put a switch in that lights up, that does absolutely NOTHING!
Just to add a little bit more confusion into the world
スコット
Mattsonics
Post
by Mattsonics » Fri Oct 16, 2009 8:08 pm
Here we go again....
I have another switch (retro fitted, with a small LED in it) to the left of the steering wheel. It illuminates when pressed.
It's not the fog light - that's on the right. Have looked at everything I can think of.
Thoughts??
Matt
Gaza69
Post
by Gaza69 » Fri Oct 16, 2009 8:10 pm
mister munkey
Post
by mister munkey » Fri Oct 16, 2009 8:46 pm
Mine had something like that.
I think it used to have bullbars & spots in its Japlife but it came over here without. Only bothered to trace the old wiring down to the front end after fitting my own bars & spots though.
jaylee
Post
by jaylee » Fri Oct 16, 2009 8:49 pm
Scott
Post
by Scott » Fri Oct 16, 2009 10:08 pm
スコット
thedogsbollox
- Tribal Elder
Post
by thedogsbollox » Fri Oct 16, 2009 11:25 pm
I found one whilst fitting my Low Coolant Alarm. On the right hand side beside the Corner guide switch. There is a switch blank there but behind there is a plug and wiring. Couldn't figure that one at all. Also when i removed the panel under the steering wheel, stuck to the back of it was a small black box about the size of a ciggy packet, whats that?
brorabongo
Post
by brorabongo » Fri Oct 16, 2009 11:38 pm
and mine
ボンゴの激怒 pictures
Run your fingers over my Bongo, and I'll run my Bongo over your fingers!!
Post
by missfixit70 » Fri Oct 16, 2009 11:43 pm
thedogsbollox wrote:I found one whilst fitting my Low Coolant Alarm. On the right hand side beside the Corner guide switch. There is a switch blank there but behind there is a plug and wiring. Couldn't figure that one at all. Also when i removed the panel under the steering wheel, stuck to the back of it was a small black box about the size of a ciggy packet, whats that?
The wiring & plug could be the loom for front fogs?
Stick a photo of the box up, could be a turbo timer mebe? any switches or anything on it?
brorabongo
Post
by brorabongo » Fri Oct 16, 2009 11:45 pm
What does the parking pole switch look like? could it be it?
ボンゴの激怒 pictures
