Well, after my head gasket failure was resolved (replacement engine from discount trucks got be going again; they appear to be great in the pre-sales & the doing; less great in post-sales communication...), I fitted a leisure battery and split-charge relay kit (willinton via ebay shop), and off we went for a lovely couple of weeks away using the bongo for what it was bought for
Used the car, mostly at weekends on and off since then. She's not been turned over, however, for about a fortnight now, just sat on the driveway all big & green.
However, the dog and I went out to the Bongo today, planning on a couple mile run out into the countryside then an afternoons walking.
However, el-Bongo, she was dead. Appears to have run out of electricity. We took the misses corsa (always fun with an 8st great dane/german shep. cross in the back!).
Upon return, grabbed my multi-meter, and checked both batteries. Both returning about 1.8v
OK - lets try charging thinks I, and retrieves the device from the garage.
Connected to main battery, with all wiring in situ. Plug in, pop - fuse blown
Odd thinks I, wonder if the charger has gone bad? Connect it to LB, new fuse, plug in, all good, happily forcing in just shy of 14v, interior lighting starts to work when doors open, etc.
Soo - my question then, is where do I start? Is there an obvious battery fault which is the cause of the fuse blowing? I can probably jump start the Bongo from the corsa tomorrow (poor corsa!) and see if it can put any juice back into the battery itself, but wondered, if there is a battery fault, is that likely to be a bad thing to do? dangerous?
Or, could it be a wiring fault that's caused all this? and its just that the voltage is so low that it's popping the fuse? If so, any tips on where to start tracking this down? could the voltage sensing relay in the split wiring kit have gone bad? any way to test this with a multimeter? etc?
Thanks, as always, for your advice and help!
Gavin.
