Mis-fire and white smoke
S Jacobs
Post by S Jacobs » Fri Sep 11, 2009 11:34 am
On a cold or damp morning my Bongo has a rough start shaking (mis-fire) with White smoke from the exhaust. I have had the glow plugs checked but the are fine, could there be any other problem. It has done only 67000 miles and has just had a full service plus cam belt change.
Yours S Jacobs
sparkymik
Re: Mis-fire and white smoke
Post by sparkymik » Fri Sep 11, 2009 9:01 pm
S Jacobs wrote:On a cold or damp morning my Bongo has a rough start shaking (mis-fire) with White smoke from the exhaust. I have had the glow plugs checked but the are fine, could there be any other problem. It has done only 67000 miles and has just had a full service plus cam belt change.
Yours S Jacobs
Check this thread quite new
http://www.igmaynard.co.uk/bongo/forum/ ... ke#p336624
hope it helps
Sparky
The Bongo has gone. Long live The Bongo
Hymer Camp Swing 544/Fiat Ducato 2.3jtd
Rhod
Post by Rhod » Fri Sep 11, 2009 9:16 pm
Mine occasionally does something like this in winter. Sometimes it does it on start up, but other times it will start ok, but then die a shuddering death at the first junction. A bit of churning gets it going & it'll be fine for the rest of the day - usually. Having discounted banjo-filter, fuel filter, air filter, battery & glow-plugs, I have a feeling that it's linked to the EGR in some way. The fact that it only occurs in cold damp weather, is intermittent & seems fine once the engine is warmed means that it "feels" like a sticking valve somewhere... Will get around to removing the EGR at some point!
