Help Needed. Drivers Window Stuck DOWN!
ummmm
Post by ummmm » Fri Sep 04, 2009 6:28 pm
Hi all
As you can see from the title I have a bit of a problem. Long story but in a nutshell think the kids managed to break the rocker swith for the drivers window. it was a bit flakey so we decided to not use it until we got it checked at the garage. Unfortunately i knocked it as i got into the van today and the window went down. The problem is it will not now go back up. Is it possible to take the switch out and swap the plugs on the back so i can use the passenger switch to return the drivers window up and then leave the Drivers switch 'not plugged in'. It would appear to be intermittent and i don't think it's the wiring in the door loom as the other window still operates as normal from both switches.
Can anyone point me in the right direction of how to prise out the Electric window switch from the door. I guess it's just got some noby bits at the sides or top and bottom.
I'm not too bothered about getting the window working again just getting it back up to the top as i reckon it may rain tonight.
Rgds
Craig
ummmm
Re: Help Needed. Drivers Window Stuck DOWN!
Post by ummmm » Fri Sep 04, 2009 7:08 pm
We live in Lymington New Forest and have a slight problem. Our drivers door window is stuck, unfortunately it is on the down position. This may seem like a far out solution but if you live near by could i borrow your drivers door switch for about 30 secs to put our window up until i can get it fixed properly. I've removed mine quite easily and it just has one plug on the back. As i said we are based in lymington and can travel where ever may suit.
Kind regards
Craig.
crazy uncle gray g
Post by crazy uncle gray g » Fri Sep 04, 2009 7:28 pm
:lol: CrAzY.S got it covered dont panic :lol:
cheers! party on dudes.
Post by missfixit70 » Fri Sep 04, 2009 8:17 pm
Nice one Crazy, what did you cover it in? :wink:
daveblueozzie
Post by daveblueozzie » Fri Sep 04, 2009 8:21 pm
crazy uncle gray g wrote::lol: CrAzY.S got it covered dont panic :lol:
bongo forum to the rescue again, nice one crazy.
Lost without my Bongo.
ummmm
Post by ummmm » Fri Sep 04, 2009 9:59 pm
Thanks to Crazy i now have my window in the right place. Now just got to find a replacement switch as this one seems to have a mind of it's own.
Thanks Again
Craig
New Forest Terrier
Post by New Forest Terrier » Sat Sep 05, 2009 4:46 pm
I only got your message after Crazy had already rode to a very efficient rescue. Pleased to find the worst of the crisis is over.
Murphy's law always says windows stick open when rain is due, as do sunroofs.
There is a new Bongo breakers in North Baddesley. Could be worth a try for a switch no adress but phone 02380 733995 or 07860612360. Link here
http://cgi.ebay.co.uk/Mazda-Bongo-Break ... 286.c0.m14
The BewilderBeast - V6 Mean Green Tintop with LPG and 321 Away Montague Conversion
Post by missfixit70 » Sat Sep 05, 2009 5:10 pm
Duff link* try this - http://cgi.ebay.co.uk/Mazda-Bongo-Break ... 286.c0.m14 Apparantly no window switches though.
*If you copy the shortened links from the thread, it won't work, you'll have to click onto "quote" on the bottom of the post to be able to see & copy the full link to then paste it elsewhere :D
