We were about to start a journey up North in the Bongo and did a 5 minute run to fill up with fuel. As we were driving away, having just gone up and over a short hill, I glanced at the Temperature gauge and it had moved from its normal 11o'clock position to about 2pm
Turned back for home immediately (taking it very slow) - the temperature gauge then dropped back to the normal position. Checked the collant level and it is a little above minimum - considering it was serviced a few months ago and was definitely full then, it looks like it has been losing coolant.
Since I'm a mechanical numpty a few questions:
1. Can I just top up the coolant into the header tank since it is still at a reasonable level - I'll need to drive it to a garage.
2. Anything obvious I should be looking for? I had a quick check for leaks under the Bongo but I couldn't see anything.
3. My brother suggested that perhaps the thermosat was sticking and it had opened when the temperature went down. Does that sound reasonable?
Any help gratefully appreciated...
Iain
