Moderator: Muzorewa
Bring out your inner Ape with 20% off at Go Ape!
Available to any existing Garmin sat-nav owner.
Think you can handle three hours of tree top adventure? Can you climb 40ft up a rope ladder, Tarzan Swing into a giant rope net then zip wire through trees, crawl through tunnels and tackle high wire rope bridges? If the answer’s yes, you’re ready to Go Ape! To redeem the offer book online at goape.co.uk or call 0845 643 2034 quoting GSN336
> Go Ape website
I tried a few discount codes but none of them worked so I gave up after searching around for a while. Some of them are ending this weekend or are only valid mon-frihembramacho wrote: Tried the 20% discount with the C&C Club. It accepted the code, but the £25 cost remained the same.Booked it anyhow!
Andrew
