dandywarhol wrote:Had a bit more of a delve but am not any further forward in understanding why our Bongo, and seemingly just a few others, has 195/80, 215/70 tyres specified. Certainly there are plenty of "new shapes" out there with "normal" (195/70, 215/65 or 215/65 all round) tyres fitted now, and I've only found one reference to some (sic) later Bongos having the higher profile tyres - so I still don't know if it's a rare mutation, or if it did did relate to all new shapes at birth. Perhaps we shall never know - as they keep saying in "Who do you think you are?" (which should be sub-titled "Who cares?", in some cases
I was under the impression that the winter M+S tyres were a higher profile on the bongo - I think I read that in the owner's handbook.
PS - I don't "tramp on" all the time Ron - it's just not that kind of vehicle - but there's been occasions when the traffic is moving smartly on quick A class or N class French roads and I don't like to hold folks up behind me.
"M+S"?
You're right dandy. There are several Bongo variants/grades specified with 195SR 15, 215/70 15 tyres, in the handbook but I don't know what the "grades" in question (e.g., "RF-V") mean. Do you? Are they all winter spec Bongos? Strangely, they're also the ones specified with lower ground clearance, 155 mm instead of 175 mm, so I took that to mean body skirts - which ours does not have.
Anyway, according to the Amayama index of models/grades/years, they do not mean new type. Presumably a 195SR 15 front tyre has an 80% profile, although ours is actually plated 195/80 15, to go with its 215/70 15s on the back. No mention of 195/80 15 in the handbook, as far as I can see.
Re "tramping on", that was just a gentle leg pull, and I also used to ride bikes (EDIT: Oh, the bit about bikes was in another thread!) - with exhilaration as one of the benefits, except in 'orrible cold weather. It's true though, that having survived our roads, driving from age 17 to now 71, I don't require quite as much cornering grip as younger drivers might need - but often haven't got
Good braking performance, to compensate for perhaps taking 5 or 10 minutes to decide to push that pedal, is paramount
No, that''s a wind up too. My reactions are, thank god, still pretty quick.
