Just wondered if anyone could help with our battery problem? We've recently realised that our leisure battery is no longer charging via the alternator. It used to charge it up pretty well and it is also wired so that we could have the fridge on while we were driving. The leisure battery itself is fine at charging if we use an electric hook up and it will hold it's charge.
We checked the alternator and this is working and happily charges the main bongo battery but when you test whether the flow is going through to the leisure battery nothing is happening on the meter.
Does anyone know what could be causing the problem?
Thanks for any help. Lauris.
