alarm for leaving lights on?
Barley 1981
Post by Barley 1981 » Wed Aug 12, 2009 2:03 pm
Is there an alarm available that beeps when you leave your lights on?
thanks!
westonwarrior
Re: alarm for leaving lights on?
Post by westonwarrior » Wed Aug 12, 2009 2:05 pm
yes there is a bleeper that sounds if you leave the lights on and take the keys out built in.
does yours beep iff you open the door with your keys in?
Barley 1981
Post by Barley 1981 » Wed Aug 12, 2009 2:08 pm
will try it when the cuprit gets home from work shortly, thanks!
I have never done it obviously, (yet) hehe
westonwarrior
Post by westonwarrior » Wed Aug 12, 2009 2:12 pm
most disable the beeper so if yours doesn't work check the connector behind the cover at the drivers right foot,
Blue connector disconnecting stops the beeps
Barley 1981
Post by Barley 1981 » Wed Aug 12, 2009 7:00 pm
Thanks Rob,
No it doesn't beep, can anyone tell me which wire to re-connect, there are lots and can't see an obvious one which is not connected....
thanks
Tanya :?
westonwarrior
Post by westonwarrior » Wed Aug 12, 2009 7:48 pm
as there is now another thread running on this I will lock this one
http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=33948
