Glowplug Light and Fuses
Dean
Re: Glowplug Light and Fuses
Post by Dean » Fri Aug 07, 2009 5:07 pm
Thanks for the varied and interesting answers!
So far I've put a brand new scavenger sensor in (on the tunnel!), so the connection should be ok, my engine doesn't get that hot as I have fitted a Mason Alarm and the gauge sits at 12 o'clock and add a few minutes for going up hill.
I saw a white connector behind the dash when fitting the alarm below the wiper stalk (ish), but couldn't see anything to connect it to so left it.
I think Kirsty's idea of having a diagnostics machine plugged in would be the next step. Maybe the suppliers have one as I'm taking it back tomorrow due to a gas ring not working on the stove either
jaylee
Post by jaylee » Fri Aug 07, 2009 5:28 pm
Dean wrote: I saw a white connector behind the dash when fitting the alarm below the wiper stalk (ish), but couldn't see anything to connect it to so left it.
Was it hanging loose?
Some people disconnect this to stop the beeping when the keys in the ignition & the doors open.. & it does.. !!
But it also made my glow light flash...! #-o
Dean
Post by Dean » Fri Aug 07, 2009 5:47 pm
I think some wires were connected to it that led off somewhere, though they don't look like they have been fitted as an afterthought; the wiring looks like the normal Mazda wiring. All my buzzers bells and whistles work (annoyingly!)
Post by missfixit70 » Fri Aug 07, 2009 5:58 pm
Dean wrote:I think some wires were connected to it that led off somewhere, though they don't look like they have been fitted as an afterthought; the wiring looks like the normal Mazda wiring. All my buzzers bells and whistles work (annoyingly!)
Have you got, or did you have a turbo timer fitted? it could be the wiring loom for that
The two 6 pin sockets - male & female - are plugged into the existing ignition loom, thus providing a spare take off ( the 3 pin plug & separate wire) for the turbo timer to be plugged in. This shouldn't make the glow plug light flash, but it's easy enough to remove the loom & reconnect the original male & female connectors.
Dean
Post by Dean » Fri Aug 07, 2009 6:17 pm
Now we're getting technical :?
The loose plug looks like the smaller one in your photo
Post by missfixit70 » Fri Aug 07, 2009 6:22 pm
You've got a pm :wink:
Dean
Post by Dean » Sun Aug 09, 2009 9:16 am
The light turned out to be the waste gate actuator. When the fitter swapped the pipes it stopped
Post by missfixit70 » Sun Aug 09, 2009 1:02 pm
Not really understanding that one :? but as long as the poroblem's solved :wink: Was I right on the turbo timer loom?
Dean
Post by Dean » Sun Aug 09, 2009 9:14 pm
Me neither...he just swapped the pipes over and the light went out. I might have got the name wrong...maybe a waste valve actuator?
He didn't think I had any wiring for a turbo timer
Post by missfixit70 » Sun Aug 09, 2009 9:32 pm
What did he think the spare connection was then?
Dean
Post by Dean » Mon Aug 10, 2009 9:35 am
He just said that Mazda tend to use just the one loom a lot so people end up with wiring and connectors that aren't used in that particular model, such as front fog lights etc. He didn't know what it was without tracing where it went,which we didn't have time for. If I get under the dash again, I'll take a photo if that would help to explain?
Post by missfixit70 » Mon Aug 10, 2009 12:24 pm
Probably not to be honest, as you'd need to see what it was connected to as your guy said.
