I have searched the forums and also looked at the factsheets, but cant see anywhere the fuse for the rear lamp. have checked the bulb and the front lamps work just not the rear.
am i right in thinking that it will fail mot without it?
rear fog lamp don't work!!
Re: rear fog lamp don't work!!
It will fail the MOT without it.
Probably an in-line fuse as they are aftermarket fittings - not needed in Japan. Have you tried looking for any non-standard switches, often tucked under the dashboard.
- missfixit70
Rear fog lamp is a retro fit, so it could be anywhere, trace the wiring from the back of the switch. Could even be a loose connection. Is your's a dangly jobbie, flush fit in the bumper or modified reverse light?
francophile1947 wrote:It will fail the MOT without it.
Thanks for that
