Stupid question... is it normal to see small amount of oil around the seal where the cylinder head joins the block, on my newly acquired 2.5 diesel it appears there is a bit, its not using water or oil as far as I can tell nor is there any non normal smoke from the exhaust.
is it a big job to replace the gasket? is it a diy friendly job as I assume you wouldnt need to have the head re-skimmed etc.
thanks
Tom
oil around rocker cover gasket
Re: oil around cylinder head gasket
oops my mistake its the rocker cover gasket,
im less worried now, should I be?
- westonwarrior
no its usual to have that
Re: oil around rocker cover gasket
You'd be unusual if you hadn't got an oil leak there
love u guys
, another quick question, the engine sounds a bit rattley when idling, is this normal, when revved its pretty much ok
Its done 78k miles, the previous owner tells me its had the cambelt done but its due a fluid/filter service soon I think, Its a great practical car and the camper roof is ace, im hooked on getting a conversion done now!
- Location: in a place far, far away, well Somerset for now!!!
welcome to the forum and to ownership - if you put your location in user control panel top right - local people to you might be able to help - also go to xome meets to look at others conversions - give youloads of ideas for what you do or do not want when you get yours converted!!!
good hunting don't rush into anything or you might end up with something you don't want.
