Muted Fog horn??
francofontain
Re: Muted Fog horn??
Post by francofontain » Fri Jul 31, 2009 12:43 pm
Eat Aunt wrote:
francofontain wrote:Noticed it a couple of times when accelerating up hill, a noise I can only discribe as a muted fog horn from under the passenger side somewhere? It sound like some sort of pump engaging??? :?
Anyone?
Franco
It could just be a mechanical part of the vehicle vibrating . Happened with a vehicle I had years ago when accelerating uphill under load.
It didnt make the horrble 'muted foghorn ' type noise when accelerating on flat roads.
If you downshift, or reduce amount you are accelerating uphill, does the noise reduce/change ?.....
Yes it does the noise goes away on deceleration.
dave_aber wrote:
francofontain wrote:Havent got a digi temp gauge/warner etc but the temp gauge stays the usual 11o'clock
Cheers all
Franco
They all do that, until after you have overheated. Don't trust the 11 o'clock reading. Fit a mason alarm.
Might well be nothing to do with your fog horn issues - but I'd be erring on the side of over-cautious with a Bongo cooling system.
(In fact, i have a low coolant alarm, and a mason alarm - and my Bongo's still on a boat somewhere!)
Mason alarm next purchase me thinks!
