thermostat location
thermostat location
Urgent help required. Where is the thermostat on the bongo. Stuck in a field with no idea.
"Living the Dream"
Re: thermostat location
I've never looked but, judging by the bleeding posts, it must be where the bottom hose comes out of the enginesamuel wrote:Urgent help required. Where is the thermostat on the bongo. Stuck in a field with no idea.
Tim, Allan's mobile is 07970301013, I tried ringing you back
The Janner Vanner
passenger side of the engine just bt the alternator,the water hose ges into a haousing which unbolts from the bottom with two bolts
Tim,
Where abouts are you ? if you need help getting back to St Austell let us know.
Tim,
i've PM you my contact details if you need help.
Cheers Paul
Cheers Paul
Hi Guys
Home safe and sound. Going by the white smoke from the exhasust its time for a new head gasket!! The time bomb has eventually gone off!!!
Thank you for everyones input.
Tim
Tim
"Living the Dream"
