hi from NZ again all my van has been well behaved from repairing the blown head gasket and replacing the radiator but 2 new issues
and i have noted others have had them too
heater fan front has gone unsure if they burn out or bearings go but i remmeber water getting in was an issue so could someone redirect me to the photo's of it please
and master drivers door switch is on its way out i read a list somewhere of other model mazda parts that fixwd this
regads all and thanks i advance Lee
my van my van my grrrrrrrrrr van
- missfixit70
Re: my van my van my grrrrrrrrrr van
http://www.igmaynard.co.uk/bongo/forum/ ... 43&t=28727 should point you in the right direction
seems in need authourity to enter some of the info "ian"
Membership number?
If you're paid up you will have received several new passwords today.
Hi Lee, regarding the front heater fan motor... Check that the drain hole in the top scuttle is unblocked, if blocked water can spill over from the channel directly onto the front motor, causing it to seize...
You don't need to be a member to access the FAQsBob wrote:Membership number?
