cuffemark wrote:the housing has no pump mechanism(im presuming it usually does like in the manuel)
I thought that too, but not all bongos fuel pump has the primer fitted to it.
But I think you have to bleed the fuel system when the engine is turned off???
If that doesnt work it might be a case of crap in the fuel lines?, not common but has been a problem in the past for some bongos, try empty the diesal tank and then take off the fuel lines and give them a clean
