Post
by francophile1947 » Sun Jul 12, 2009 8:58 pm
You've obviously got a leak from somewhere. Have you checked the hoses in the engine compartment and underneath?
The temperature gauge is useless, so you can't rely on that - by the time the gauge shows anything, the engine is often ruined.
If you are having to put a kettle of water in, the header tank must be empty. You must bleed the system before using the car, because there will almost certainly be air in the system. I assume, as you make no mention of overheating, that she is only doing short trips.
Is there any smoke/steam from the exhaust or signs of water in the oil?
