Dreaded Hold light flashing after fuel pump replacement
Hello
Whilst travelling through northern Greece recently, my fuel pump died and spewed fuel all over the shop. I had to get it rebuilt at a Bosch diesel specialists, but after they replaced it, the hold light started flashing regularly (one flash for about 1 second, then off for about 1 second). I tried a couple of things that people have told me, namely disconnecting the battery for 3 minutes, then reconnecting. (did this with one terminal disconnected, then both terminals disconnected). After more discussion with people, I tried the following (with one terminal and again with both terminals):-
Disconnect the battery
Stab down on the Brake pedal
leave for 2 minutes
Reconnect the battery
Start engine and leave to idle for 3 mnutes.
Neither of these got rid of the flashing hold light.
I now have no 'hold' function, and the gear box does not ' kick down', so acceleration is slow and gear change is at low revs giving apparent low power going up long hills etc. I now have to manually change down to 'S' to get acceleration when needed. Since I live in Exeter, Devon, this will cause me grief.
Since the light is flashing regularly as opposed to a code, I don't think it's a gearbox problem, but I can't see anything left undone by the fuel pump repair
Please can you help
Many Thanks
leave for 2 minutes
Please can you help
Many Thanks
- westonwarrior
Re: Dreaded Hold light flashing after fuel pump replacement
the hold light will flash regularly unless you short the diagnostics terminal correctly to force it to give the code
This is in the fact sheet in the members area
I would guess that a wire is not connected after the work or something got damaged during the work
first step is to get the fault code and see what it says
Could Allans in Plymouth help as they are v. good with Bongos?wiliamsgj wrote:Hello
leave for 2 minutes
Please can you help
Many Thanks
Hiya I had this problem after having my fuel pump tinkered with. it turned out that the TPS had been moved. it sits beneath the cowling on the drivers side aft of the gear lever and you adjust it with a screwdriver. i don't know if anyone else on here has a pic of it or what. if not I will take one and post it on here later. cheers
Bingo, Bango.........
- westonwarrior
Thanks to everyone who's replied so far - I'll try tinkering with the TPS when I get home to Exeter this weekend. Otherwise I'll contact the Plymouth people mentioned above - they may be able to help.
How do I find the fact sheets mentioned above - all I can find are a few about reversing seats, etc.
many thanks
many thanks
does sound like a tps problem. the tps sits on top of the fuel pump and is actuated by the throttle cable. the tps provides feedback to the ecu to control the gearbox so if its not working it will appear as a gearbox problem. if you can use a multimeter you shold be able to diagnose it ok. keep us posted
- widdowson2008
Facts sheetswiliamsgj wrote:Thanks to everyone who's replied so far - I'll try tinkering with the TPS when I get home to Exeter this weekend. Otherwise I'll contact the Plymouth people mentioned above - they may be able to help.
many thanks
http://www.igmaynard.co.uk/bongo/members.htm
in 'Members area' Top right hand side
Steve
- missfixit70
You need to be a paid up member of the club to access the factsheets, link at the top of this page.widdowson2008 wrote:Facts sheetswiliamsgj wrote:Thanks to everyone who's replied so far - I'll try tinkering with the TPS when I get home to Exeter this weekend. Otherwise I'll contact the Plymouth people mentioned above - they may be able to help.
many thanks
Again - thanks to all who replied - after much piddling about, it turned out that the fuel pump was still defective (although cured enough to get me home from Greece). I replaced the fuel pump with a second hand one, and all is now cured.
How do you close these theads when complete?
- missfixit70
You don't
people may want to add to the topic - including yourself later on. Glad you got it sorted
Great news wiliamsgj and thanks for getting back and updating us.
A question for our techies now:
I'm trying to think which bit of an incorrectly rebuilt fuel pump might cause the HOLD function to stop working. Is it because it was not fuelling the engine properly so the gearbox was being informed of inadequate torque or summat?
Mike
Mike
- dandywarhol
Depends on the year of Bongo - post '99 have an electronic pump which'll have electronics to trigger the hold light - I don't know which model yer man has.
If its an earlier model then I'm stumped, the TPS rarely flashes up a hold light, but it will flash it up as a code during interrogation
