Hazards u/s
blobber
Hazards u/s
Post by blobber » Wed Jul 01, 2009 11:03 pm
Hi peeps, not long back off my jollies, unhitched trailer, drove off, indicators making correct noise didn't notice if green lights were flashing until later on the motorway when there was no noise and no green lights and no hazards.
A quick check today revielled 10A hazard fuse blown but not indicator fuse. Replaced fuse, indicators worked for about 3 flashes then gone again, Hazard fuse again and now indicator noise very fast (blown bulb?).
Where do I start looking for the fault, rear light cluster conns? disconnect trailer wires to isolate hookup?
Also, are the indicaror bulbs standard 21w push in type?
Hope someone can help the oldest girl on the block !!
Alan & Dot
Yes sir, I can Bongo !!
jaylee
Re: Hazards u/s
Post by jaylee » Wed Jul 01, 2009 11:07 pm
I would look at the trailer hook up first.. Something may be shorting. :wink:
Possibly where it's tied in with the rear lights...
Re: Hazards u/s
Post by missfixit70 » Thu Jul 02, 2009 12:11 am
I think the flasher unit is down by your right foot behind the panel to the right of the accelerator pedal, but I'd check the trailer socket wiring first as Jaylee said.
