where do i connect the vacuum pipe please ?
Hi to one and all ....please can anyone help with a troublesome pipe, I have just fitted a new cylinder head on the freda, and cannot for the life of me find where one of the ends go on a small pipe ...its the small vac / pressure pipe coming off the air filter feed pipe which go's around the engine to the turbo, its got a little one way valve with an arrow on it, its just got me stumped ?? its location is under the drivers side seat, many thanks for taking the time to read this Richard
Re: where do i connect the vacuum pipe please ?
Hi Richard The pipe with the one way valve has an aluminium heat shield over it and goes toHi to one and all ....please can anyone help with a troublesome pipe, I have just fitted a new cylinder head on the freda, and cannot for the life of me find where one of the ends go on a small pipe ...its the small vac / pressure pipe coming off the air filter feed pipe which go's around the engine to the turbo, its got a little one way valve with an arrow on it, its just got me stumped ?? its location is under the drivers side seat, many thanks for taking the time to read this Richard
one of the solenoids on top of the inlet manifold. If you need to Know exactly which one PM me with your e-mail address and I will send Photo
Cheers Brian
Wow! Brian you really know the Technie stuff
Cheers Anna
Cheers Anna
Wow! Brian you really know the Technie stuff![]()
Cheers Anna
Hi Anna I only know this because mine was brittle and broke so I replaced it with a one way valve from a fish tank .
Cheers Brian
or you can use a biro refill
How terribly clever you guys are.
I might learn something yet
...............If I can remember
Cheers Anna
Cheers Anna
Big Thanks to Brian .....great photo showing assembley many thanks Richard
