lowering bongo suspension
Richard hird
Post by Richard hird » Thu Jun 11, 2009 7:50 pm
Does anyone out there no where to get a set of lowering springs and shocks to help reduce pitch and roll. Thanks Rich
peanutcrusher
Re: lowering bongo suspension
Post by peanutcrusher » Thu Jun 11, 2009 7:54 pm
bell hill garage sell them they are in bath. spoken with them a few times very helpful.
Bongo now work later !!! :) :)
scanner
Post by scanner » Thu Jun 11, 2009 7:58 pm
Richard hird wrote:Does anyone out there no where to get a set of lowering springs and shocks to help reduce pitch and roll. Thanks Rich
Be careful if yours is 4WD, as you can end up with front drive shaft problems - do a search and check out Bigdaddycain's post on the subject.
Richard hird
Post by Richard hird » Thu Jun 11, 2009 8:02 pm
Thanks for the quick replies. it is a 2wd and has 19" alloys
maxheadroom
Post by maxheadroom » Thu Jun 11, 2009 8:03 pm
Richard hird wrote: has 19" alloys
nice 8) 8) pics please
Keep the Faith
scanner
Post by scanner » Thu Jun 11, 2009 8:24 pm
Richard hird wrote:Thanks for the quick replies. it is a 2wd and has 19" alloys
What tyres?
Richard hird
Post by Richard hird » Fri Jun 12, 2009 8:54 am
it has 235x40 tyres
the janner vanner
Post by the janner vanner » Fri Jun 12, 2009 10:52 am
Your Bongo sounds as if it has been pimped a tad, any chance of a picture? and could you please give your location, as this helps the anoraks point you in the right direction as to where is the best place to find parts etc
The Janner Vanner
Richard hird
Post by Richard hird » Fri Jun 12, 2009 11:19 am
it has been pimped a bit, just not quite enough yet. I'm in Harrogate, N.Yorkshire. I'm new to this so i'll try and get some pictures posted shortly.
oxfordpaul
Post by oxfordpaul » Fri Jun 12, 2009 12:52 pm
Dude is there any room to lower your bus? those rims must be really filling the arches :!:
Any fool can make things complicated, it takes real genius to make things simple
Richard hird
Post by Richard hird » Fri Jun 12, 2009 1:56 pm
yeah there' s enough space to drop 40 t0 45mm, thr tyres are a 35 not a 40
scanner
Post by scanner » Fri Jun 12, 2009 2:30 pm
Richard hird wrote:yeah there' s enough space to drop 40 t0 45mm, thr tyres are a 35 not a 40
Are those tyres up to spec on load index?
At least 92 front and at least 96 rear?
Some folks have reported problems with under-rated low profiles.
Richard hird
Post by Richard hird » Fri Jun 12, 2009 2:36 pm
yes they have mate. the first set split, almost like someone had slit them with a stanley knife. makes them expensive though
