Split Charge Relay Clicking in and Out
- dreamwarrioruk
Re: Split Charge Relay Clicking in and Out
they are usually fixed both top and bottom so your just adjusting one end, well it is on mine
mike, jo and emma
- stilldesperate
- Tribal Elder
Not CDO? It's similar, but the letters look better in alphabetical order!BongoMTBer wrote:
Did I mention I have OCD?
SD
Cheers Mike.mikeonb4c wrote:I'll have a look and get back to you if I find them. PM me with a reminder if I haven't got back to you by the weekend
stilldesperate wrote:Not CDO? It's similar, but the letters look better in alphabetical order!![]()
SD
Fixerised
I tried moving the set point lower and all that acheived was when the split relay kicked in the LB just drew even more current which made the whole situation worse!
Anyway, I have fitted a new alternator and everything is back to normal. Hurragh!
- stilldesperate
- Tribal Elder
Glad you got it sorted, and good to hear what it was
Here's to no more probs!
SD
SD
Goodo - I looked up that stuff yesterday evening and was about to scan it for emailing to you. But to be honest, its just common sense and a multimeter....as you've discovered. Adjust the pot. voltage threshold so it clicks on reliably when alternator in action and clicks off reliably when it is not.BongoMTBer wrote:Fixerised![]()
- dandywarhol
Whats the charging output now with the a/c on?
- missfixit70
My alternator died not long after the same thing started happening.
I had taken it down to the alternator guy, when it started playing up, he checked it out, reckoned it was ok, so I got onto Willinton, who very kindly set up a split charge with a lower charging range & swapped them, seemed ok for a while, the alternator packed up about 2 weeks after
luckily, still within warrantee by a few days
I don't know if the fact that the solenoid that brings the revs up when the ac kicks in wasn't working had a bearing on it too.
Worryingly, I did notice it clicking away the other day when I started up, but then the leisure battery has been working hard the last few weeks
Oh, so you're up then. Where's this report on The Italian Job I wanted on my desk 1st thing?missfixit70 wrote:My alternator died not long after the same thing started happening.
I had taken it down to the alternator guy, when it started playing up, he checked it out, reckoned it was ok, so I got onto Willinton, who very kindly set up a split charge with a lower charging range & swapped them, seemed ok for a while, the alternator packed up about 2 weeks afterluckily, still within warrantee by a few days
