...... said it was from memory !scanner wrote:According to http://www.miata.net/garage/tirecalc.html the difference is exactly one inch.
215/65-15" = 26" diameter
215/65-16" = 27" diameter
Just thinking about it - it HAS to be exactly an inch as the tyre on both rim sizes is exactly the same width and profile so that is the same for both wheels.stilldesperate wrote:...... said it was from memory !scanner wrote:According to http://www.miata.net/garage/tirecalc.html the difference is exactly one inch.
Not necessarily.stilldesperate wrote:Yup, but it'd need all four doing, and (I'm guessing) Shogun std size tyres (at /65 profile) will be cheaper than /60's?
That can't be badIt ain't a problem, the speedo is spot-on, ride is good, and the revs are a bit lower, helping mpg a little.![]()
The centre of the hub is still in the same place!Just wondered about the extra height causing probs with the drive-shaft couplings (covered on the forum), and thinking of body-roll being slightly increased.![]()
That'd be cool, if you could leave the roof up and drive fast enough, when you brake hard you could do a roly poly!northerntaff wrote:what about increaing the height...particularly at the back
That depends upon how much the lowering springs have lowered it and how "fresh" the normal springs are as all springs "sag" with age (don't we allMatEmily wrote:Another quick techie question,
How much extra height would normal springs give me?
Yes it can beAlso she(the Bongo) seems to be alot lower at the back than the front, why is this, is it the weight, its fitted with side kitchen and rock n roll bed, can't be that heavy can it?
The best solution is supplementary air suspension.Is there anything I can do to lift the rear slightly?
Majorbloodnock wrote:That'd be cool, if you could leave the roof up and drive fast enough, when you brake hard you could do a roly poly!northerntaff wrote:what about increaing the height...particularly at the back
