Cruise control info required
srs41
Post by srs41 » Wed May 27, 2009 6:14 pm
Planning on fitting an Audiovox cruise control , any one know the pulses per mile of the Bongo speed sensor .
scanner
Re: Cruise control info required
Post by scanner » Wed May 27, 2009 6:42 pm
No idea for miles but if this helps.
Quoted from the Waeco MS-50 manual.
If the Cruise Control takes over at a speed of less than 40kph but no longer functions at speeds over 80-120kph and the LED flashes more than once per second, the black wire loop on the electronic module will have to be cut. This will change the impulse count from 1,250 per km to 8,000 per km
So I would guess it must be about 12,800.
srs41
Post by srs41 » Mon Jun 01, 2009 9:02 pm
Thanks for that , I worked it out by trial & error , there are 4 settings to choose from tried them all & everything seems ok at 8000 PPM ,
