Headlight bulb block connecter
mister munkey
Post by mister munkey » Mon May 25, 2009 4:17 pm
Low beam gone on o/side headlight. Tried changing bulbs yesterday but found the plastic block connecter at the back of the bulb has cooked, become brittle & fell apart in my hands. :(
Drove the 60 miles or so to Wheelquick this morning - safe in the knowledge that they could get it sorted, only to find them shut. :evil: Wrongly assumed that a 7 day a week business would be open on a Bank Holiday.
Question being - is this a compatible "off the shelf" bit or do I need to faff about trying to find a breakers that have one?
Bonus question - Why was that overheating in the first place?
helen&tony
Re: Headlight bulb block connecter
Post by helen&tony » Mon May 25, 2009 4:38 pm
It's a standard bulb, so i would think standard connector....as for the other burny type problem....bad earth, worn connector in block, water....dirt....A replacement block should do the trick
apole
Post by apole » Tue May 26, 2009 9:30 am
If it's just the connector that plugs into the rear of the headlight bulb any autofactors should have one, saw one in Halfords the other day. Make sure you get the right type mind. :shock:
