grinding rubbing noise from rear wheels when I brake
stansyerman
Post by stansyerman » Wed May 13, 2009 12:46 pm
grinding rubbing noise from rear wheels when I brake could it be new brake pads required
Re: grinding rubbing noise from rear wheels when I brake
Post by missfixit70 » Wed May 13, 2009 1:01 pm
Either that or something's trapped in there, it could be you'll need to replace the discs too.
Rhod
Post by Rhod » Wed May 13, 2009 11:00 pm
Sounds as if the rear pads need replacing - mine made the same noise at the end of their life. I had to drive 100 miles or so before I could replace them but there was still material left on the pads & the discs were fine.
