Hi, a mate of mine is thinking of getting an SGL5 to tow his off road landrover around to competitions etc..
Has any one towed car trailers and how did it go.
he's looking at about 3 tonnes total.
cheers
E
Towing Capacity of 4WD Bongo?
Re: Towing Capacity of 4WD Bongo?
No idea as I have never towed anything in my bongo. Perhaps Bongoplod could help you, he goes everywhere towing a huge caravan with his bongo.
Tony
Tony
- missfixit70
3 tonne'd be too much safely I reckon,
Standard bongo is anything from @ 1700-1870kg from memory which is @ 1450 - 1590kg, you can tow up to 100% safely, but, you also have to take into consideration the max nose weight which is 85kg.
Further info on the towing factsheet in the members area - http://www.igmaynard.co.uk/bongo/member ... towing.pdf
from this thread - http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=30566haydn callow wrote:As I understand it.. the caravan club recommends not more than 85% of the weight of the towing vehicle.
Not an expert on these thing but sounds too heavy to me.!!!
Fact sheet is the way to go as suggested by Kirsty
I believe the max towing weight is 1600kg, about 1 and a 1/2 ton.
I think a total weight of 3 ton for a Landy + trailer will be too much.
Brian
Brian
- helen&tony
From my experience...definitely not...take a leaf out of the "Travellers" book...a large truck or van.
