Front left wheel making groaning noise, when turning left
Nashy
Post by Nashy » Tue Apr 21, 2009 5:28 pm
Hi All
I did send another thread about my van making a horrible groaning noise, which is getting worse when i turn left whil driving, to the point where the noise is apparent while driving in a straight line - even my steering wheel shakes a little bit
Though when idle turning the van lock to lock it doesn't make the same noise. does this indicate that it cant be the steering wheel fluid???
Any ideas chaps
Tammy
Re: Front left wheel making groaning noise, when turning left
Post by francophile1947 » Tue Apr 21, 2009 5:32 pm
Jack the wheel up and see if you can wobble it - could be wheel bearing or even loose wheel nuts :shock: I would check it before driving it again, just in case it's a loose wheel.
Post by missfixit70 » Wed Apr 22, 2009 12:59 am
Trouble at t'Mill
Post by Trouble at t'Mill » Wed Apr 22, 2009 9:20 am
"Though when idle turning the van lock to lock it doesn't make the same noise. does this indicate that it cant be the steering wheel fluid???" I agree this suggests it ain't simple lack of fluid, I'm afraid. I also don't see lack of fluid (or any other fault with the power steering, for that matter) causing wheel wobble or a groaning noise.
Also agree with above - don't drive it again until the cause is confirmed (we've had a rusty wishbone snap on this forum before...).
Could be collapsed wheel bearing, failed CV joint (is it 4WD? If not, then it ain't the CV joint...), or suspension joints as mentioned above.
Or something else... :)
But best candidate for 'groaning' and 'wobble' is wheel bearing I think.
jaylee
Post by jaylee » Wed Apr 22, 2009 9:59 am
If the noise changes pitch with speed, the first thing i would get looked at (as the suggestions above) is the wheel bearings..!
There was a whine that changed pitch with speed coming from the back near side wheel on my partners 7 year old Micra last year.. You guessed it, the bearings were going! Quite common on the new shape apparently.. :roll:
Post by bigdaddycain » Wed Apr 22, 2009 11:19 am
And of course you have checked the obvious things such as wheelnut tightness etc? And it's just possible (dunno if you have alloy wheels fitted) That the spigot ring (if fitted)on the hub isn't aligned properly,stopping a flush fitting of the wheel on to the hub. That could cause a droning sound, and wheel wobble.
It may be worth checking the tyres for evidence of "blocking" too... If one (or more) of the shock absorbers are failing, then the lack of rebound on the shockers can actually damage the tyre(s), this can be manifested in a degree of deformation in the tyre(s), or indeed actually knocking chunks from the tyre! :shock:
jaylee
Post by jaylee » Wed Apr 22, 2009 12:06 pm
bigdaddycain wrote:And of course you have checked the obvious things such as wheelnut tightness etc? And it's just possible (dunno if you have alloy wheels fitted) That the spigot ring (if fitted)on the hub isn't aligned properly,stopping a flush fitting of the wheel on to the hub. That could cause a droning sound, and wheel wobble.
Would this cause wheel skipping & loss of consistent contact with the tyre tread & road surface, resulting in a longer breaking distance as well Ste? :D
Post by bigdaddycain » Wed Apr 22, 2009 12:29 pm
I would imagine so mate! :shock:
