tyre sizes
Re: tyre sizes
Mine had the different front and back sizes when I bought her 5 years ago but the excellent bongo mechanic at the garage suggested 215's all round, so I did and they went straight on the original rims no probs.
Re: tyre sizes
If you are running 17" Wheels the standard sizes are irrelevant to you - just make sure the load index of the tyres you get fitted is greater than 96 so you have the right carrying capacity on the rear axle.debbiepritch wrote:just been looking through the members info and reading this...and am now more confused than ever![]()
I need 4 tyres asap and at the mo have 215/55 A17 all round....got a quote today...but wondering now if I should go for omg i can't remember what they werebut different sizes back and front...if I'm forking out for all 4 want to get it right
thanks if anyone can help![]()
Debs
Re: tyre sizes
Just checked and most 215/55-17s are 94 only some are 98 make sure your supplier gets you the right ones.
The 98's.
The 98's.
- friendeedebs
Re: tyre sizes
you've lost me...in english please LOLscanner wrote:Just checked and most 215/55-17s are 94 only some are 98 make sure your supplier gets you the right ones.
The 98's.
the ones on now are budget and got 93V???
Debs x
- friendeedebs
Re: tyre sizes
how do I know wheel size..?? or is that to thick a questionscanner wrote:If you are running 17" Wheels the standard sizes are irrelevant to you - just make sure the load index of the tyres you get fitted is greater than 96 so you have the right carrying capacity on the rear axle.debbiepritch wrote:just been looking through the members info and reading this...and am now more confused than ever![]()
Debs
Debs x
Re: tyre sizes
This explains it all.debbiepritch wrote:you've lost me...in english please LOLscanner wrote:Just checked and most 215/55-17s are 94 only some are 98 make sure your supplier gets you the right ones.
The 98's.
Debs x
http://www.blackcircles.com/general/sidewall
In short 93 is too low for the back, but OK on the front.
Tyres are your (and 2 tonnes of Bongo's) only contact with the road, so my advice is get the best tyres you can.
Re: tyre sizes
My 4WD bongo came from Japan shod with 215/65/15 96H tyres all round although the hand book and door plate say otherwise. It would seem that having 215s all round on 4WD's is not just a UK preference.
Tony
Tony
- friendeedebs
Re: tyre sizes
mines 2wd does that make a diffference??MountainGoat wrote:My 4WD bongo came from Japan shod with 215/65/15 96H tyres all round although the hand book and door plate say otherwise. It would seem that having 215s all round on 4WD's is not just a UK preference.
Tony
- friendeedebs
Re: tyre sizes
thanks will give it a look in the amscanner wrote:This explains it all.debbiepritch wrote:you've lost me...in english please LOLscanner wrote:Just checked and most 215/55-17s are 94 only some are 98 make sure your supplier gets you the right ones.
The 98's.
Debs x
that's what i want...the best x
Debs
- missfixit70
Re: tyre sizes
If you've got 17" wheels, look into the Accelera215/55 98w XL tyres, should be around £50 a wheel, the same size all round, they have a slightly protruding ridge on the tyre wall that helps protect the tyre from kerbing too.debbiepritch wrote:how do I know wheel size..?? or is that to thick a questionscanner wrote:If you are running 17" Wheels the standard sizes are irrelevant to you - just make sure the load index of the tyres you get fitted is greater than 96 so you have the right carrying capacity on the rear axle.debbiepritch wrote:just been looking through the members info and reading this...and am now more confused than ever![]()
Debs![]()
Debs x
- friendeedebs
Re: tyre sizes
If you are running 17" Wheels the standard sizes are irrelevant to you - just make sure the load index of the tyres you get fitted is greater than 96 so you have the right carrying capacity on the rear axle.[/quote]
Debs x[/quote]
If you've got 17" wheels, look into the Accelera215/55 98w XL tyres, should be around £50 a wheel, the same size all round, they have a slightly protruding ridge on the tyre wall that helps protect the tyre from kerbing too.[/quote]
but how do I know if I've got 17 " wheels??
Debs
Debs x[/quote]
Debs
- missfixit70
Re: tyre sizes
It'll say in the numbers on the side of the tyres, it'll be 15, 16 or 17 - the blackcircles link that Scanner posted shows where it'll be & what the numbers on your tyre mean
Re: tyre sizes
If you can't be bothered to work it out for yourself like me then get to Wheelquick in Wigan and let Mike Snr do it all for you. I found his prices much more competitive than Blackcircle who operate from Peebles in the Scottish Borders less than 20miles from where I live.
Tony
Tony
- peanutcrusher
- Tribal Elder
Re: tyre sizes
The first reply by Kirsty answered that - did you read it?peanutcrusher wrote:so does this mean my tyres are correct or not
