...and if you do accidentally touch the glass, you can use meths on a piece of kitchen paper to clean it.scanner wrote:Pull connector off (may need a tweak with a screwdriver to free it) peel off rubber shield, release spring clip holding bulb in, remove bulb.
Refitting is reverse procedure - just DON'T touch glass of bulb with bare fingers as it can permanently mark the glass.
