Spotlights not working
Neither of them are coming on, any thoughts, fuse and bulbs seem to be OK.
Re: Spotlights not working
loose conection at the switch, or a bad earth maybe.
If they have been fitted for a while, an earth wire being corroded, or coming detached may be the prime suspect.
HAve you actually changed the bulbs for completely new ones ?
I had two headlight bulbs go recently at the same time( not on a Bongo)
They LOOKED OK.
They LOOKED OK.
Hi, no the bulbs LOOK Ok but we havent changed them so will try that. Also will look for signs of corrosion. Thanks
Mine weren't working this morning either...oh wait tho, I aint fitted em yet.
