pump
pump
anyone used something like this
http://cgi.ebay.co.uk/SILVERLINE-104616 ... 1|240:1318
to extract gearbox fluid etc?
any good?
any good?
.......... cycling more.
Re: pump
I think I have seen a thread where something like this was used for coolant pipe flushing etc.meek.tv wrote:anyone used something like this
any good?
Edit----- No It was an oil change!
Re: pump
That looks like an identical design to the Pela pump I (and many others) have but it is only 4 litres instead of 6 litres. But at that excellent price I think I could live with having to empty it out half way through and oil change. An extractor pump is a very handy thing and makes engine oil changes a doddle. Well spotted
Re: pump
It does indeed look like a small version of my MUCH MORE EXPENSIVE Pela
Re: pump
But where are both pumps made? Could the Silverline pump be yet another cheap Chinese copy of the Pela pump which appears to be the gold standard for Bongo owners.
Tony
Tony
Re: pump
I fear you may have a point. If the plastic is cheap and brittle, it may break more readily than the Pela. Mind you at that price I think I'd probably have a punt as its not bank breaking £sMountainGoat wrote:But where are both pumps made? Could the Silverline pump be yet another cheap Chinese copy of the Pela pump which appears to be the gold standard for Bongo owners.
Tony
But the Pela is worth its price and the 6 litre capacity means you can just about take all the engine oil out in one go (once or twice I've not quite managed it, other times I have - why!?!?!)
Re: pump
probably go for the pela me thinks
anyone know off the top of their heads what grade atf i need for the gearbox (is it the same for power steering) and how much ill need?
Re: pump
once again ignore my requests.
got this from here http://www.nielsencdg.co.uk/cgi-bin/sh0 ... 740_2d7160 good price for proper castrol stuffs
Re: pump
Dexron 3 for bothmeek.tv wrote:probably go for the pela me thinks
Re: pump
got this from the unit over the road
got 6litres to cover the gearbox. how much do i need for the power steering?
Re: pump
Sorry, no idea - I've only topped mine up.meek.tv wrote:got this from the unit over the road
- mikexgough
Re: pump
I got a Pela last Friday.....what a superb bit of kit....certainly impressed the neighbours....looks like many will be doing their own oil changes from now on..
Re: pump
Bought the Silverline pump last week. I decided to try it out pumping oil from a container and discovered there was no vacuum being created. I assume the pumping mechanism is at fault -it is a rather flimsy thing - so I'll be on the phone to them tomorrow. Also the plastic tube is too wide to go into my Freda's dipstick pipe. Ah well - I think I need a refund and then go for the Pela but I if I have to pay postage both ways on a faulty item i will feel agrieved.
Ron
Ron
Re: pump
Hi ronhud.
Useful to have feedback on that pump - I was toying with getting one myself!
As for return (and original) postage, I may be wrong but I think that the seller legally has to cover it if the goods are faulty - a 'long-distance selling' rule.
Almost certainly they'll try and suggest you at least cover the original postage cost, but I'd check it out if I were you and you can tackle them on it. But do confirm this first!
Re: pump
Yep, that's what I understand as well - Distance Selling Regulations (or Rules)Trouble at t'Mill wrote:As for return (and original) postage, I may be wrong but I think that the seller legally has to cover it if the goods are faulty - a 'long-distance selling' rule.
