Which Alloys go straight on .....
Just snapped up a Bongo and after some alloys... it's all a bit confusing to me,but are there any Mazda wheels that will go straight on... i.e RX7/8 ?? Thanks
Neil
Neil
Re: Which Alloys go straight on .....
there's loads of stuff on here so have a search. Try putting in 'RX8' and see what you get. Also there is adivce on the hole centre diameter spacing thingie (PCD is it called - try putting 'diameter' and 'wheel' into Search and see what comes up). Otherwise no doubt the experts will be along shortly.
Congrats on bagging a Bongo by the way.
Piccies please, we love piccies
You need wheels with a PCD of 5 x 114.3mm and a centre bore of 67.1mm. See here for wheels that can fit, especially Mazda, Hyundai, Kia and Mitsubishi http://www.alloywheelsinternational.com ... UIDE1.html
Ford Probe wheels also fit.
You can have a larger centre bore than 67.1mm, but will need spigot rings to reduce the size of the hole.
- stilldesperate
- Tribal Elder
Mitsubishi Pinins fit straight on, they're 16", so will affect the gearing.
Right, so RX 8 will go straight on then?? What are the imlpications of fitting either 16/17//18 inch wheels then(as you may have guessed my mechanical expertise you can fit on the back of a match box)
Neil
Neil
- brorabongo
You would need lower profile tyres, giving you the same rolling circumference, oh make sure they and ones at the right load rating!!!!goofyfoot wrote:Right, so RX 8 will go straight on then?? What are the imlpications of fitting either 16/17//18 inch wheels then(as you may have guessed my mechanical expertise you can fit on the back of a match box)
Neil
This link lets you calculate the size of tyre needed, depending on what size wheels you fit http://www.miata.net/garage/tirecalc.html
steviebongo
- Tribal Elder
I have mazda 5 sport 17" alloys go straight on no probs.
cheers stevie
cheers stevie
Thanks,any thoughts on the Alloys advertised for sale on here, asking around 280 for them ?
Funny enough...! A Mazda 5 was parked up behind behind me earlier..steviebongo wrote:I have mazda 5 sport 17" alloys go straight on no probs.
cheers stevie
I was checking out the alloys & thinking would they go straight on my wagon..?
Nice wheels in my opinion!!
steviebongo
- Tribal Elder
yeah I got them for nothing ,they were a warranty change over,to my benifit
- dandywarhol
I know I'll incur the wrath of some but its really important to get the offset right too - otherwise you're going to end up with safety problems in the event of a puncture or brake failure.
The offset governs a steering geometry term called scrub radius/offset
http://en.wikipedia.org/wiki/Scrub_radius
If the offset is wrong then the vehicle will pull violently to the side in the event of brake failure (non ABS cars) or a puncture AND COULD INVALIDATE YOUR INSURANCE
irrc the Bongo offset is 40mm
- mister munkey
RX8s with a 52mm offset are a potential risk then?
- dandywarhol
You'd need to make an accurate measurement from the centre of the top strut bearing down through the centre of the bottom ball joint til it intersects with the ground. The centreline of the wheel/tyre MUST be INSIDE that intersection - this is called NEGATIVE scrub radius. This pic shows POSITIVE scrub radius - not what you want. You would need to find out if the wheel has negative or positive offset and measure it up..
Pic2 shows how offset is measured. A 52 POSITIVE offset would push the centerline in the right direction - so it should be okay.
