front heater blower resistor
hi,bongo bods does anyone know where the resistor is located 4 the front heater blower as my blower has packed up?
- mister munkey
Re: front heater blower resistor
Theres a fact sheet in the members area, heres the bit you need . . .
The fact sheet gives a pretty comprehensive run down on the whole caboodle.Behind the central fuse box, on top of the heater/cooler matrix, there is a hinged cover.
Release the cover at the front, lift it upwards and remove. The fan resistor unit is at the
front of the housing. Remove the electrical connector and the two screws securing the
unit to the housing. The fan resistor unit will now lift out.
many thanx, just hope it is the prob & not the fan.
- missfixit70
Lots of piccies, links & info in the FAQ section at the top of the forum http://www.igmaynard.co.uk/bongo/forum/ ... 43&t=28727
If the resistor has gone, chances are it's because the fan's having problems, both can be repaired.
