bongo turning but not starting - any ideas
Re: bongo turning but not starting - any ideas
Post by missfixit70 » Sat Mar 21, 2009 12:14 pm
Posted most of it on thursday :? :lol: Good to know we're all reading form the same sheet though :wink:
bennett
Post by bennett » Sun Mar 22, 2009 11:39 am
Hellooo, thank you all so much for all our help and tips, greatly appreciated. We managed to borrow another glow plug rail from a fellow bongonaught and hurrrray!!!!!! it works fine. So first thing tomorrow we will be ordering a new part.
Thanks again from sunny copplestone :P
Tracy
ps did any of you watch the rugby yesterday? Neil happy England won but I'm sad Wales lost!!!! but good game!
Post by missfixit70 » Sun Mar 22, 2009 11:40 am
Glad you're sorted :D
dandywarhol
Post by dandywarhol » Sun Mar 22, 2009 12:25 pm
scarlet wrote:Hi a good diesel should start with out the glowplugs as they only warm up the air in the bores and you only realy benifit from this when its cold.Have you got 12v going to the glowplugs if you have a pre 2001 i think its fuse 18 on the internal fuse block i think it's a 10amp fuse. The relay only operates for a few seconds only when you turn the ignition on so it will take two people to test enless you remove the relay and make up some lead to test it with.Have you got 12v going to the stop solinoid hope this helps.
cheers
martn
If you can't start it cold then how are you going to start it scarlet......... :?
A cold indirect injection engine will have a real difficulty statring - even in summer, so glowplugs are essential.
Although the glowplug warning lamp goes out after a few seconds, the Bongo plugs stay on for 15 seconds with just the "ignition" on, otherwise when the engine is started the timer relay can keep them on for several MINUTES depending on the ambient temperature.
Post by mikeonb4c » Sun Mar 22, 2009 12:30 pm
bennett wrote:Hellooo, thank you all so much for all our help and tips, greatly appreciated. We managed to borrow another glow plug rail from a fellow bongonaught and hurrrray!!!!!! it works fine. So first thing tomorrow we will be ordering a new part.
Tracy
Excellent. Did I read on here something about the glowplug rail shorting out on glowplugs if incorrect length glowplugs were fitted. I'm not suggesting it has anything at all to do with this problem, but I never read on here before of a faulty glowplug rail. I assumed it was just a metal strip that made sure they are received electric power, but I'm no techie and have never fiddled with mine :shock:
Post by missfixit70 » Sun Mar 22, 2009 10:03 pm
I reckon they probably meant glow plug relay Mike.
Post by mikeonb4c » Sun Mar 22, 2009 10:41 pm
missfixit70 wrote:I reckon they probably meant glow plug relay Mike.
I love you Kirsty - you're so clever =D>
Post by missfixit70 » Sun Mar 22, 2009 10:56 pm
:oops: Aw shucks :lol: Had me confused too, I might be wrong in my assumption though :wink:
Post by mikeonb4c » Sun Mar 22, 2009 11:13 pm
missfixit70 wrote::oops: Aw shucks :lol: Had me confused too, I might be wrong in my assumption though :wink:
I suspect you're right 8)
Post by bigdaddycain » Mon Mar 23, 2009 2:24 am
cheers
martn
No matter how painful it is, i have to agree with dandy here :P (just joshing luv)
Ultra efficient common rail fuelled diesels can start cold without the aid of a pre-warmed combustion chamber,but an indirect injection old lump as fitted to the bongo just won't start cold without the help of the glowplugs. The compressed fuel vapour heats as it's compressed, but can't achieve flashpoint temperature inside the dense cold walls of the combustion chamber without help from the warm air generated via the glowplugs. Notice how difficult it is to start a stone cold engine with just one lazy plug?
