Head gasket - not convinced
- westonwarrior
Re: Head gasket - not convinced
yes but there is working and "hot"
mine gets very hot
mine gets very hot
Same herewestonwarrior wrote:yes but there is working and "hot"
mine gets very hot
Quite right franco and I think that's the point. If (and it is 'if') you can make a persuasive case that any reasonable owner should have known that significant things weren't working and declared them, then you'd think you could claim that they deceived you. Being honest, it sounds like a long shot with a private vendor, but it could be worth checking out with citizens advice (they must deal with plenty of situations like this).francophile1947 wrote:If it's not losing any coolant, why did you have to top it up last Friday![]()
I find it hard to believe the seller didn't know there was something wrong - I'm sure I'd notice if my heater didn't work in the winter![]()
Thanks for all your info guys. A bit of a conundrum isn't it? I think I will try the cheapest option first by getting the Rad flow tested, then bleed the system for airlocks, then see what happens. I maybe lucky and the problem disappears. If not, then probably have to go the head gasket route. Is it possible to have the head pressure tested without removing it from the block? That way it would help me make a decision before I go ahed with the work.
Once again, thanks guys.
Craig
Craig
- dandywarhol
No but what can be done is to fit a pressure tester to the expansion tank, start the engine and see if the gauge builds up pressure indicating a gasket/crack.
Thanks for all so far guys. Coolant system pressure test completed - shows no leaks or pressure build up. My local garage (who are trusted by me, but not Bongo specialists) are still telling me that the gasket could still be gone. Again, as at the beginning, I am not fully convinced.
Advice as to how to procede would be really appreciated.
Best Regards
Craig
Best Regards
Craig
- stilldesperate
- Tribal Elder
You're now down to:
No leaks
No Pressure build up
Bongo runs fine
But your heater isn't getting hot.
I'd bleed the system (follow the factsheet on this), and try again.
*If* the head/gasket *has* gone, you won't make it any worse......
Did you have the Hydrocarbon "sniff" test done on the fluid? If there's any leak from the head, the exhaust gas analyser will show a reading. Mine (having been told twice that the head had gone), gave a "0" reading, I was told it would be round the "100" mark (parts per million) if there was a problem.
Hope this helps,
SD
No leaks
Bongo runs fine
Hope this helps,
SD
- dandywarhol
The sniffer check is usually for CO2, carbon dioxide - the chemical ones certainly do detect CO2 but I presume hydrocarbons could also be detected.................
If the headgasket has gone it WILL make it worse - liable to damage the head!
- stilldesperate
- Tribal Elder
Sorry, didn't make it that clear, I'd bleed the system to see if the heater works, I wouldn't think that bleeding it would cause further problems.stilldesperate wrote: I'd bleed the system (follow the factsheet on this), and try again.
SD
