Basic Maintainance Classes and Coolant Alarm Fitting
Moderator: Ian
- haydn callow
Ian has asked me to do a few classes along the same lines as last year. This will be very basic stuff and each class will last 40 mins approx. The system of booking last year worked very well, book in with Ian at the main Club shop/tent and then be either at my pitch at the allocated time or in the "Big Top" if it's raining.
There will be 2 classes on Thur/Fri/Sat @2pm and 3pm (total of 6 classes) Max peeps per class will be 6.
There will be a nominal charge for each person attending and this will be donated to charity.
Because of the above and the lack of a Coolant Alarm Fitter this year I will only be able to fit a very few alarms and these MUST be pre booked by PM to myself. There will be a charge of £10 for each Pre Booked fitting and this again will go to charity. Alarms/BMW Clocks will be available to buy on site but will only be fitted if time allows...these unbooked fittings will be £15 and again the money will go to the charity.(you could fit them yourself {dead easy} and I will be around if you get a problem {unlikely})
The charity being supported by myself this year is the BRPS (British Retinitis Pigmentosa Society)
Any questions ..please let me know. I did run out of alarms last year so some indication would be good so I can get enough together.
Re: Basic Maintainance Classes and Coolant Alarm Fitting
Haydn, don't forget to take peoples contact details if they buy on tic.
Manny
Manny
A Bongo by any other name would still drive as sweet.
- haydn callow
Sorry...after last year...No Tick...lesson learnt
- dandywarhol
Would that be the clocks or money?haydn callow wrote:Sorry...after last year...No Tick...lesson learnt
- brorabongo
dandywarhol wrote:Would that be the clocks or money?haydn callow wrote:Sorry...after last year...No Tick...lesson learnt
- You've Been Bongod
can you reserve me one of those nice led clocks please hayden ??
ps how much are they nowerdays , i have a bmw clock to trade in
- haydn callow
Sorry...I only do BMW clocks.....
- missfixit70
Simon Jones is the man for the roof mount led ones.You've Been Bongod wrote:can you reserve me one of those nice led clocks please hayden ??
no you have mis understood me hayden
i want the bmw one with the blue light behind it like the ones you had last year at the bash
- haydn callow
Ah....no worries....I can do that to yours probably at the bash...If not then a stright swap will be fine.
haydn callow wrote:Ah....no worries....I can do that to yours probably at the bash...If not then a stright swap will be fine.
thanks haydn
- Jillygumbo
Hi, we bought one of your clocks last year at the Bash and my OH is still looking at it, scratching his headhaydn callow wrote:Alarms/BMW Clocks will be available to buy on site but will only be fitted if time allows...these unbooked fittings will be £15 and again the money will go to the charity.(you could fit them yourself {dead easy} and I will be around if you get a problem {unlikely})
Jillygumbo, Tonto & Ruca
- haydn callow
We will sort somthing out.
Treat it to one of Haydns turned aluminium rings to go round it too - it lifts the look of the clock to a new level - a quality look, not cheap and not expensive to buyJillygumbo wrote:Hi, we bought one of your clocks last year at the Bash and my OH is still looking at it, scratching his headhaydn callow wrote:Alarms/BMW Clocks will be available to buy on site but will only be fitted if time allows...these unbooked fittings will be £15 and again the money will go to the charity.(you could fit them yourself {dead easy} and I will be around if you get a problem {unlikely}). It takes pride of place above the cd/radio and shows a permanent 10am! Would appreciate you fitting it for me if you have time. Prepared to pay for this. Will contact you when we get there - not sure which day yet but will be Friday at latest, and staying till Monday. Is this Ok?
...and I will have about 10 roof mounted clocks ready for the Bash. Drop me a pm for details.missfixit70 wrote:Simon Jones is the man for the roof mount led ones.You've Been Bongod wrote:can you reserve me one of those nice led clocks please hayden ??
